mattusctrojan
#1 Posted : Friday, July 7, 2017 12:04:42 PM(UTC)
mattusctrojan
purchased home in 2014 with new GE side by side fridge
model GSCS3PGXGFSS
SERIAL IS LA 403850
it cools fine in the freezer and fridge
however, the display where you dispense water and ice is acting weird after a power outage
when you press the lever for ice or water it flashes the temp and does not dispense water or ice
tried unplugging it and same issue
also tried resetting the display by setting it off by raising the temp, then hitting cool to reset to factory default, still flashes temp and does not give water or ice
any ideas?
PNWDrew
#2 Posted : Friday, July 7, 2017 10:11:54 PM(UTC)
PNWDrew
The power outage may have damaged the DC circuit that powers the display board or the transformer on the main board. This also has a DC fan in the freezer and I'd expect it to have also been affected if the DC supply is bad, any odd noises, howling, whining, surging etc... from the freezer fan?
