skilpatrick
#1 Posted : Thursday, June 29, 2017 6:33:31 AM(UTC)
skilpatrick
Power button has begun intermittently failing to turn on the machine. When powered on, the machine performs flawlessly. Is there mechanism in the power button that can fail? If so, can I replaces just the power button? Or am I doomed to replace the entire control board?
#2 Posted : Thursday, June 29, 2017 3:58:05 PM(UTC)
You have to open the control panel to find out if the button itself worn out or the whole control board has gone bad.
Start the disassembling from removing the power to the washer. Then remove the top panel which is secured with 3 screws from the back of the washer.
The power button Part number: AP3884097
The control board Part number: AP3995160
Good luck.
