TJennings
#1 Posted : Friday, June 23, 2017 11:17:00 AM(UTC)
TJennings
Oven was not baking properly. Wouldn't heat enough to bake thru. Replaced bake element as it was not heating red. After replacing I noticed it turned red the first time I turned it on. Now it doesn't. So replaced temperature sensor. Still not heating to set degree according to oven thermometer I bought. What do I check next? Thanks!
#2 Posted : Friday, June 23, 2017 5:58:28 PM(UTC)
What is the difference between the set and real temperatures? If it is within 35°, then it can be adjusted. If it's more, the control board would need to be replaced. Unfortunately, this part is no longer available.
The instructions on how to adjust the oven temperature are in the Use and Care Guide.
