zingbop
#1 Posted : Friday, June 16, 2017 7:41:32 AM(UTC)
zingbop
If I had to guess (and I do), I'd say the most likely culprit for my considerable leak is a bad tub seal. I got down into the washer to the point of taking the inner tub out. The next step eluded me. Do I need to essentially take the entire machine apart (i.e. from the top and from the bottom) to access the tub seal? Any direction would be appreciated.
