raindogmx
#1 Posted : Saturday, June 10, 2017 11:44:35 AM(UTC)
raindogmx
I have a KFP0933 KitchenAid mixer which uses this motor: picture PN W10467162.
At the rear end of the motor shaft there is a sensor which I assume is for RPMs: picture
There was a magnetic ring around the shaft, which I broke: picture
And that's my story. I need to replace it because now the mixer does not work properly.
I took some rough measurements and the ring seems to be 15 mm in diameter, 8 mm inner diameter with a 3.5 mm thickness and 5 mm height: diagram
I don't even know how to search for it. I've been looking for ferrite toroids but can't find any with the same measurements. I also don't know anything about the material.
Please and thank you
barkster
#2 Posted : Monday, September 18, 2017 10:42:07 AM(UTC)
barkster
did you ever find this piece or specs? I thought about 3d printing one but I need to know how many magnetic spots are on the ring. I assume only 1.
raindogmx
#3 Posted : Monday, September 18, 2017 11:29:26 AM(UTC)
raindogmx
No, I ended up taking it to a service center where they first said they would need to replace the whole assembly but in the end just fixed it with a piece but they didn't give me any details and I haven't opened it to see what they did. Maybe I will.
