Mike72903
#1 Posted : Monday, June 5, 2017 12:48:08 PM(UTC)
Mike72903
how do I remove this water valve outlet line without ruining anything. The one at the top of the picture. Everything is plastic of some sort. I'm tempted to pry harder than I already have but....:eek: picture attached. There are two powered solenoids and one is for the ice maker and the other is unused as the unit has no water dispenser. I want to switch water outlet hoses. Both solenoids are wired in parallel electrically so both should operate together. Can I do this instead of buying a new water valve? It's an Electrolux French door bottom freezer model. Thanks, Mike
EDIT. okay, found out how to get the water lines out.. DOH! Any problem with switching the water lines between solenoids?
Mike72903 attached the following image(s):
