This is the situation, just the other day the cooling fan on the oven goes on and off sporadically for a split second to a couple of seconds. Not always the same and at no definite time interval. It can be an hour or go on and off 2 or 3 times consecutively.
I just wanted to update. After using the oven, last night, to cook supper the cooling fan problem has become hardly noticeable. The cycling of on and off has diminished to almost none.
I just wanted to say that the problem has come back with the same frequency as before.
