mackie6399
#1 Posted : Tuesday, May 23, 2017 10:18:49 AM(UTC)
mackie6399
I'm at a loss. All components are working on oven except bake and broil. I have reset breaker, unplugged and checked for fuse. This model does not have one I believe. clock has not worked for several months. It comes on for time set once breaker reset but goes off once time set. This never stopped oven from working before. No warning signs, worked last night then nada the next day.
#2 Posted : Tuesday, May 23, 2017 8:14:58 PM(UTC)
According to the wiring diagram, there is the thermal circuit breaker. It is located under the top panel or on the back of the unit.
Check the thermostat for continuity. If it's open, the thermostat would need to be replaced. If it shows continuity, the EOC (clock/timer) would need to be replaced.
The range hi limit thermostat Part number: AP4587847
The EOC Part number: AP4552111
Here are the break down diagrams for the Frigidaire electric range Model FFES3015LWA
Good luck. Keep us posted.
