I have a Kenmore dual oven and I recently replaced the lower bake element in the bottom oven. Element works in bake mode but not in convection mode. Upper oven works as normal. I need some help because I do not have the tech sheet.
So, here's an update to my issue. I cycled the oven through all modes. Non-convection bake: both elements work Convection Bake: both elements work - fan running Convection Roast: Preheats using the broil element only. Fan running. Does not cycle to the bake element. Anyone have some suggestions?
