tractorman44
#1 Posted : Thursday, May 11, 2017 2:56:06 PM(UTC)
tractorman44
This reefer has the ice maker in the door. The ice level sensor does not light up, flash or anything. I didn't see anything in the troubleshooting that covered this particular issue. There is no attempt to fill or make ice so logic suggests the symptoms are connected.
Any suggestions would be greatly appreciated.
CitadelBlue
#2 Posted : Friday, May 12, 2017 9:04:19 AM(UTC)
CitadelBlue
Could be the sensor board (s) or a broken wire under the freezer that runs up the lower door hinge
