f1loco
#1 Posted : Sunday, April 30, 2017 5:23:49 AM(UTC)
f1loco
I have no lights on my control panel, again. Yes, thermal fuse is ok, yes, replaced the main board already. Last time, I found a sequence on line to "reset" the actual touch control panel, but can't find it. All the ones I find don't seem to be the same. I did go through the touch pad ohm testing all the buttons seem to be working at least down to the control board. I did warranty the old one out this morning just to be safe, but still no lights. I remember the Kenmore Pro had a difference sequence I found on a forum somewhere when the control panel is installed, but I can't find it again - help?
