Freezer internal temp -10 when set at -2. Display reads 86 hi temp. Replaced control board and spliced new defrost thermostat on defrost heater. Is it possible heater is bad and causing this issue?
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
