Just replaced entire drum belt kit along with the motor shaft pulley (which was the original culprit to start it all). Once re-assembled, the dryer will start, heat will fire and then it shuts down in exactly 1 minute. This will happen on all cycles. Dryer has been completely cleared of any lint and venting is clean.
Tested continuity on thermister Tested continuity on thermal fuse Wires all seem to be in tact and connected.
What's next?
:confused:
Update - Which has not completely resolved the issue. I did order and replace the thermister and now the dryer will run on an air cycle. I am unable to run it past the 1 minute mark on any heated cycles. Also, if I change over to a heated cycle while in the air dry cycle it will immediately shut off with the same F22 error code. I can only think to go after all the sensors and fuses related to the heat at this point?
I am wondering if there was a series of events that took place when the dryer stopped due to the motor pulley breaking as the dryer did not tumble but was still hot inside?
Any thoughts or feedback appreciated before my next parts order.
Continued Update - I have since replaced the moisture sensors, thermal cut off and the thermstat F. The thermister wire harness tested fine for continuity. Continues to stop on the any heated cycle for 60seconds and then shuts off with the F22 error. Everything that I have found online leads to the thermister and or wire harness. I am too far in to give up now..
Thoughts... anyone?
