Like the title says, the water starts going for a few seconds then just stops. It will do 4 cycles of this and then just stop altogether. I tried the diagnostic thing where you push the heated dry button 6 times, and after I did that it started blinking the Normal light and the Delay 2 light. Just blinking over and over. It's also leaving water in the bottom. Please help, no clue what's going on or how to figure out what's wrong!
Ok so I just took it apart the bottom inside after watching a video, and the motor seems to rotate fine and there's nothing in its way. Sounds like the motor is damaged and needs to be replaced?
