The bake light flashes rapidly and the touch panel will beep whenever you touch any button but not respond (except for the clock set button). The stove burners remain fully functional. I have let the unit sit all night with the power disconnected to reset by it. Whenever you initiate the BAKE, BROIL, or CLEAN cycle, the function will begin but within the first 5 to 10 minutes, the function will abruptly turn off and the BAKE light will begin flashing. The only way to reset is to cut power to the unit and allow it to reset. No diagnostic codes appear on the display. Thank you advance for your assistance
Press and hold CANCEL and BROIL pads for 3 seconds to enter the Quick Test mode. Once the control has entered the “Quick Test” mode, release both pads. Press COOK & HOLD pads simultaneously. The last diagnostic code should be displayed. Post the results.
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Error code F° . Oven doesn't work but stove does . When set to temp it automatically says it is at that temp . Thank you
