Randy26
#1 Posted : Monday, April 17, 2017 4:34:18 AM(UTC)
Randy26
The Hot Cooktop light stays on all the time, even when all burners are off and cold. I do not have ready access to a volt meter. Can somebody tell me what the common cause (specifically what part) of this failure is (I suspect each burner has a sensor), and if there is a way to detach wires individually to isolate the burner?
