Can not get the back screw out of the cover. Nut driver does not seem to go on it . Any suggestions as to how to get it out? Frigidaire side by side.
It's a pretty deep hole. Your nut driver may be too fat to fit in there, or the head may be rusted, or it may have been replaced by another screw. Can you use a mirror and a flashlight to see it? There's no other trick I know beside breaking the plastic or somehow drilling the head off.
Thanks Drew. Did finally get it . Cant find a nut driver to fit these things. Its the one in the back that is so hard to get to. The plastic mold is not big enough did however put another small washer on it when I went back in with it so I would not have this problem again.
