I need assistance on connecting larger black wire connector and smaller blue wire connector from the washer to the electronic control board slots. The slots when viewed from left to right are PRG, UID, RV, SERVICE, EXP AND UIP. I know one of the connectors came out of slot UIP, unsure of which. I should have taken a snapshot of these before disconnecting. I was installing a boot and had to remove the control panel. So can you assist me in getting the two connectors where they belong?
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
No. The wire connectors connect into slots in the module in back of front control panel. I suspect this powers the steam and extra rinse. I did reconnect the 3 black and 4 blue wire connectors onto front control panel and installed panels back on washer. So far everything is working. Thanks for your assistance.
