Dash1482
#1 Posted : Saturday, March 18, 2017 11:00:02 AM(UTC)
Dash1482
side by side built-in
Refrigerator door will start to close from open position then stops. Contacted parts direct and so far they have sold me a lower and upper hinge bracket, but they can not tell me how this closes the door. Is there a spring, cam, piston?
I have researched and do not see a closing cam on this model refrigerator. Since it is a built-in, it does require alot of work to pull out to get the door off, so I want to do this one time and have it fixed.
Kenmore Elite
Side by side
Refrigerator/Freezer
401.40483800
Rhab
#2 Posted : Tuesday, March 21, 2017 9:20:09 PM(UTC)
Rhab
Kenmore Elite
Side by side
401.40483800
HUH?? On most refrigerators the trick to get the door to close is to jack up the front. I do not know Kenmore, but there should be leveling screws on the legs or rollers in the front. Get something & some help to lift up the front. You should be able to see the legs and the screws to jack them DOWN to lift the front. OK Rex R. Bahr
