howard S
#1 Posted : Sunday, March 12, 2017 7:58:38 PM(UTC)
howard S
I have a WP oven (IBS550Pww00) that went dead with no display after my wife for the first time used the self cleaning feature. I replaced both thermal fuses that were opened and still no display. I then changed the control board and now I am getting PF on the display . What should I do next?:mad:
Howard S
teamlouish
#2 Posted : Tuesday, March 28, 2017 7:58:11 PM(UTC)
teamlouish
Pf is what you're supposed to see. You fixed it. Which 2 thermal fuses did you use? My exact one (same model number) broke like yours did after doing a self clean and I can only find the back thermal fuse (Oven Shutdown Thermal Fuse), not the one in the plastic sleeve at the top (Control Panel Thermal Fuse). What part number did you find for that one??
From the installation guide, when the display shows Pf, turn the knob to Off, and press OK button twice.
I found the installation guide on some other site, page 6.
Oh, also, whats the control board part number in case I have the same issue as you do. Thank you.
