This is a KitchenAid dual convection electric oven with an upper microwave oven, model KEMC377KSS05. With door closed, the digital display reads "DOOR" and the microwave will not operate. Traced it to one of the fuses (see attached). However I'm having a hard time identifying the part number so I can order. This fuse is on top of the microwave unit, towards the back. Thank you. palmeroj attached the following image(s):
