I have a KitchenAid Superba gas convection stove (I cannot find the model number on the stove. One of the burner knobs will not cause the clicking necessary to light the burner. If I try to light this burner with this knob, it will not click. If I light one of the other burners, it will light, so it is getting a spark.
I need to know which part I need to purchase and I need to know how I get at this part to replace it.
Any help is appreciated.
Thanks, Chris
Groups: Expert
You're going to need a model number to get the right part.
You probably need a new switch, but they usually come as a part of the little wiring harness that goes to all the control valves.
Do you have any idea where the model number can be found on the KitchenAid stove?
I finally found the model number KitchenAid Model YKGSC308LS0
Groups: Expert
Thanks, appreciate the help.
Chris
