NSXBill
#1 Posted : Friday, March 10, 2017 2:44:04 PM(UTC)
NSXBill
Washer cycles are acting erratic, probably a CCU, but I checked the resistance of the valves and they measured 1038 for hot and 1018 cold. Manual says should be ~990 ohms. Says if the measurement is "tens of ohms out of range" to change the valve.
jimctec
#2 Posted : Saturday, March 11, 2017 10:56:14 AM(UTC)
jimctec
If both valves will open and allow water in, and shut off tightly, I would look elsewhere for a problem.
