My front 2 burners function correctly. My rear 2 burners will not spark with their corresponding knob, they will only spark if I turn either knob for the front burners.
Its a GE range/oven with a glass top.
Groups: Expert
Originally Posted by: R.Burgundy  My front 2 burners function correctly. My rear 2 burners will not spark with their corresponding knob, they will only spark if I turn either knob for the front burners.
Its a GE range/oven with a glass top. Its probably the switches/harness. If all four burners spark, then the problem must be in the switches.
GE WB18T10343 Harness Switch - AppliancePartsPros.com
