My washer does not spin on any cycle, it fills but does not spin.
I replaced the door switch, but the washer still only fills and does not turn. I checked the Belt, and it still is on and lookd fine. Shocks are solid, and drum spins. The timmer dial turns and turns. Help ??
Joined: 6/13/2014(UTC) Posts: 781 ![Man Man](/Themes/yafvision/male.gif) ![United States United States](/Content/images/flags/US.png) Was thanked: 1 time(s) in 1 post(s)
We can only imagine you replaced the door switch to the washer lid. "Stranger things have happened." If so then the timer may have burnt contacts. Try replacing it... Frigidaire 134803600 Timer - AppliancePartsPros.comOh BTW thank you for not calling this a stackable washer, when it is in fact a Laundry Center (combo unit).
