Ok here is the problem with this stove I am having to light the stove to burner each one of them manually because that is the only way to light them as if the igniter is not working can you let me know if there is a igniter for the stove top burner and where it is located if it even has one.
Groups: Expert
i am now able to get sparks how ever i turn one of them on and i notice that they all ignite does this occurs every time to all of them and just lite the the one that the knob is on i am just wondering about how this also another quick question if say for example that you turn on the front right igniter and the left rear starts to ignite would you say that the wires may be crossed up this is happening on another stove where the knob works another burner and not the one its intended to. i will post another question when i get the model for this stove.
