The control panel is across the top. All buttons work except the on and delay on.
The model number you posted does not come up. Please verify it and repost.
Thank you.
Groups: Expert
Hello, my friend. The problem with this dishwasher most likely caused by a broken ribbon cable wich connecting the console (buttons) and the electronic control. So in order to fix it, the console assembly would need to be replaced. The console assembly Part number: AP4508531
Good luck. Gene.
