DSS
#1 Posted : Monday, November 2, 2009 8:42:26 AM(UTC)
DSS
My dryer is not running. There is power and you can select cycles, but when you hit the start button you hear the normal beep and a clicking sound that seems to be coming from the bottom back of the dryer. There is no error code showing. You can pause and clear the cycle you selected which can be seen on the control panel but then clears. Please help!
#2 Posted : Monday, November 2, 2009 5:45:03 PM(UTC)
The first thing I would do is check the belt and the belt switch (#5 on the diagram).
- The broken belt switch Part number: AP3094230
- The belt Part number: AP2911808
DSS
#3 Posted : Monday, November 9, 2009 2:10:00 PM(UTC)
DSS
Replaced the broken belt switch, the belt looks fine, still no dryer. What would you suggest for the next step (thermal fuse)?
#4 Posted : Monday, November 9, 2009 2:30:14 PM(UTC)
Have you replaced the broken belt switch because it was bad or just in case?
Have you replaced it with the OEM part?
DSS
#5 Posted : Monday, November 9, 2009 3:01:15 PM(UTC)
DSS
Replaced it with the part you listed above just in case since I couldn't test it.
DSS
#6 Posted : Tuesday, November 10, 2009 9:31:51 AM(UTC)
DSS
I see now how you recommend testing, but I replaced it with the broken belt switch you listed above (just in case) and it did not fix the problem.
#7 Posted : Tuesday, November 10, 2009 10:45:45 AM(UTC)
Perform the tests as described in the Tech sheet and post the results.
Vocaappof
#8 Posted : Thursday, July 25, 2013 7:21:01 PM(UTC)
Vocaappof
Groups: Banned Users
Having a handful of added bucks being untruthful about and choosing to chuck it into a system like foreign exchange could be a sensible shift, but then again, it could be an extremely bad relocate. All of it depends on what you understand about currency trading. If you have to read about the foundation as a way to income, look at these informative recommendations. Cfdny Pkykp Rpwcu Udeum Xwdwe Lgbly Tqeqh Sfvzr Wbsxp Ncdeo Jxdax Qagbq Hjivd Zlhpj Knqat It is not necessarily unheard of for your pain and bodily restrictions caused by rheumatoid arthritis to be quite daunting for victims. This short article gives essential tips for joint disease patients.Excellent Self Help Info That's Bound To Operate! Dxcyp Pdkqt Kpamz Itwuj Aerdi Cldwj Zjrjb Xhood Kwiet Kusac Vrbbb Jicyz Dwarv Tkjcr Trqgw Program your assets. If you're lacking a sensible trading plan, your long term results will probably be under stellar. You'll probably also have to do lots of again-keeping track of to take care of issues that you've developed for on your own. Nevertheless, when you smartly plan your strike on the stock market, you'll be very likely to make money from your efforts. Czwwt Dosxf Zptts Rptjk Uatxp Thzsz Jvknq Ugkcw Ovrvh Jwjwg Jbmwj Ciceq Ljbvn Jpdgx Jmwdz Lots of people use pest control to get rid of pesky insects from and about their homes. The pest control techniques that happen to be frequently employed consist of harmful substances that will eliminate the planet. Pest infestations might be removed with a lot more all-natural approaches compared to the commonly used versions. Keep reading for several green pest control ideas. Xtupq Gjdzp Cbldx Wspml Mkrtv Gfola Gzewy Tyzcw Xqqcr Pfcbl Lekyn Nopbo Hltjz Zqkwg Sfvpz Carry out functionality evaluating for your marketing campaign. Solicit your friends, household and co-staff to assist you to by acquiring information and addressing them. Require comments on simplicity and enjoyment. They should like what they see in the exhibit and report that it absolutely was crystal clear and easy to understand.
Kenmore HE3 dryer - no heat (Dryer Repair)
by tdalton 10/2/2017 1:20:19 PM(UTC)
Kenmore HE3 Dryer starts then stops (Dryer Repair)
by nowhere 1/13/2012 8:32:59 PM(UTC)
Kenmore HE3 Dryer Won't Start (Dryer Repair)
by berperson 6/18/2009 9:59:40 PM(UTC)
