I have an older thermador cooktop (PCS366) that is currently configured for LP gas. I need to convert this to natural gas and plan to drill the orifices to the proper size. I know the conversion kits for these cooktops are no longer available. Although a long shot, I figured I'd post an offer to trade in case there is someone looking to convert to LP. I have 6 orifces (p/n 15-12-094) that are marked "#112" with a hole diameter of 1.12mm for LP. I need 6 orifices (p/n 15-12-591) marked "#168" with a diameter of 1.68mm for natural gas. Listed below are the ranges/cooktops using the same orifices. Thanks!
PCS364GD, PCS364GL, PCS366, PCS484GG, PCS484WK, PCS486GD, PCS486GL, PRDS304, PRDS364GD, PRDS364GL, PRDS366, PRDS484GG, PRDS486GD, PRDS486GL
