[FONT="Arial"] Hi... Frigidaire DW model # FGBD2432KF1 Fills & empties, water does not spray at all. Tried several different cycles (rinse, normal, pots & pans, etc), killed power 30 mins to 'reset' PC board, checked internal screens & covers, no glass/bones/string, etc inside, latch functions a-ok. The motor works - pumps out just fine. The LED timer counts down cycle time as normal...it just doesn't spray water internally. The motor makes *no* sound during what should be the wash cycle, in fact it is completely silent unless filling or emptying. Fill - silence - empty...That's it. I haven't inspected the PCB or taken apart the control box on the door, nor have I gone underneath yet. What else is there? Thanks in advance [/FONT]
