The light which illuminates behind the temperature control for the lower oven no longer works? Oven still heats. Can this bulb be easily replaced?
Please see attached photos of the upper and lower temperature displays. Here you can see the lower is on but not illuminated. The upper when on shows how it should display. scripto attached the following image(s):
