JohnC.
#1 Posted : Friday, January 27, 2017 2:25:45 PM(UTC)
JohnC.
I recently purchased this used freezer. It is about 80% full and I have the temp set to keep the food at 0 degrees F. I followed the Mfg instructions and keep it in a room that is 70 degrees, no direct sunlight and there is at least 3" of air space on all sides. I noticed the compressor was running a lot, so I wired a 120v clock in parallel with the compressor circuit. After 24 hours of operation, the compressor was running 58% of the time. What kind of performance should I expect, and what might be wrong?
