Starter was burned up, replaced it with a 3 in one now the compressor starts and runs about 30 sec. and slows to a stop. unplug it and plug it back in and it will not start, Let it set for a day and it will start and again run about 30 sec. and shut down. I just bought the frig and was told it worked fine. ha ha. You think the compressor is bad?
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
The Compressor has bad bearings and is seizing up. That's probably why your original relay burned up.
