jaymaynard
#1 Posted : Sunday, January 15, 2017 7:31:17 AM(UTC)
jaymaynard
Our Frigidaire GLEF378ASD range is almost exactly 15 years old. This morning, we had a thermal runaway while baking a cake and a pan of brownies. (With sea salt caramel chips, too.)
This is the second time this happened; the previous time was about 8 months ago. The first time, there was an error code (which I no longer remember); this time, there was none; the display showed the selected bake temperature. We pulled the breaker to let things cool down.
Last time, the oven went right back to working as before, until today.
It did have one other problem: very occasionally, after turning the oven on and selecting a temperature, the display would run up to 550 F and never actually turn on the element. Resetting the temperature would make it work as usual.
A sugar-caramelization calibration test after the first runaway showed the oven was dead-on accurate, as it was before the event.
Do we need to replace just the logic board? Or is there more that I need to replace? I don't want to have to put a $200 logic board in it and not have that be the problem, or the whole problem.
jaymaynard
#2 Posted : Monday, January 16, 2017 6:44:54 AM(UTC)
jaymaynard
Update: Turned the breaker back on this morning. The oven element came on, even though the oven had not been turned on from the panel.
That pretty much says it has to be the logic board, unless there's a relay somewhere that controls the element that isn't on the logic board itself.
ThatGuy
#3 Posted : Monday, January 16, 2017 3:24:59 PM(UTC)
ThatGuy
Groups: Expert
United States
According to the wiring diagram, there is only a control board and the elements.
Parts for Frigidaire GLEF378ASD: Wiring Diagram Parts - AppliancePartsPros.com
Board part number.
Frigidaire 316207527 Oven Control Board - AppliancePartsPros.com
Frigidaire 316220804 Clock Overlay (white) - AppliancePartsPros.com
You could have your board rebuilt, It sounds like a stuck relay. Just do a search on your board part number. 316207527
