govols01
#1 Posted : Friday, January 6, 2017 6:33:19 AM(UTC)
govols01
loose change has gotten to bottom of drum and periodically will block the hose leading to the discharge pump. how do I get to the coins?
ThatGuy
#2 Posted : Friday, January 6, 2017 7:41:22 AM(UTC)
ThatGuy
Groups: Expert
United States
Here's a video. Pretty much ignore all the stuff they say until time 11:35
This part shows how to remove the top, agitator, and inner basket/drum.
So between 11:35 and 17:50 is probably what you need.
Washer Outer Tub (part #W10193886) - How To Replace
