kbcbrown2017
#1 Posted : 8 years ago
kbcbrown2017
F20 Code - researched at APP and YouTube, I ordered the Water Inlet Flowmeter, thinking it was the problem. Replaced it with new one from APP. Ran 2 loads and F20 back. In the wash cycle it goes through soap tray, but not bleach tray. By the third water cycle the barrel fills up half way, F20 comes on, just as it did before. My wife presses the pause/cancel, then switches to rinse/spin to finish load out.
I don't like to keep on changing parts out when it's not needed as YouTube guys did. What could be the problem? It appears the Water Level Switch works in the rinse/spin cycle. But the wash cycle going through the soap and not switching to the bleach and filling up the barrel half way??????
I have read in the APP about the dispenser assemble could be plugged and it appears there has been some boil out of powdered soap up through the top holes of the dispenser. I will check that today for plugged ways the water travels.
Thanks, look forward to the help.
kbcbrown2017
#2 Posted : 8 years ago
kbcbrown2017
This is Kbcbrown2017, as far as I can see no one has replied to this problem?
Am I doing something wrong as far as POSTING?
KB
ThatGuy
#3 Posted : 8 years ago
ThatGuy
Groups: Expert
United States
If I knew anything about it, I'd help, but I really don't. Sorry.
Whirlpool washer F20 code (Washer Repair)
by wstrick14 about a year ago
Maytag Frontload MHWE300VF00 F20 Code (Washer Repair)
by Whatafix 3 years ago
F20 code but only on large loads (Washer Repair)
by MaddieHayes 8 years ago
Whirlpool Duet Steam Washer - F20 Code (Washer Repair)
by ZMonet 9 years ago
whirlpool duet washer f20 code (Washer Repair)
by mindylfowler 13 years ago
