AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag LAT5914AAE Washr leaking into bin after cycle ends
my matag is quite old but still very much needed and we are having a problem with it.
after a load finishes, we have found that there is water trickling into the bin. eventually it will overfill and start leaking out. we had to turn off the water to the machine.
i had a repair guy out that spent a whopping 2.7 seconds at the house. all he did was unscrew the panel and told me its the water pressure switch, but they want $230 to replace it. i could almost buy a new washer for that much, so wanted to be sure if anyone knows for certain that is indeed the part that is needed?
any help is greatly appreciated!
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
thanks for the reply.
will try what you said and respond.
still leaks in. have ordered the part. thanks for the help!!
Washer Repair
