I have a GE bottom freezer refrigerator, model # GFE29HMDAES, and the interior light, as well as the water dispenser control board (which also has temp controls on it) suddenly stopped working. It was having no issues previously. Any ideas what might have happened? We unplugged the frig, and when plugged back in, the dispenser control board briefly lights up, but then goes blank.
I found the answer to this problem on another website. The frig goes into "Sabbath mode" for some reason. The solution to this is to hold down the Lock Controls and Dispenser Light buttons at the same time for about 3 seconds. Problem solved!!:) :)
