Ice and Water working on and off at door. - I replaced water filter and checked water pressure, I checked both door switches for continuity, I replaced ice and water solenoid valve, I checked switch at dispenser for continuity. Water seems to flow to ice maker to make ice. But they only work once in a while at the door. I thinking it may be my touch pad on the door,,,,, Any specific code to use to reset ??? Any other trouble shooting I can do to narrow down further.
Pditty
Groups: Expert
