Dabenthall
#1 Posted : Monday, December 19, 2016 10:51:29 AM(UTC)
Dabenthall
Dryer wont heat anymore. Just replaced the heating element, and still no heat. What else should I look for? Thanks
ThatGuy
#2 Posted : Tuesday, December 20, 2016 10:51:51 AM(UTC)
ThatGuy
Groups: Expert
United States
Did you also replace the thermal cutoff on the side of the element? The thermal fuse?
Was your old element burnt out/in two?
You should have 240 volts AC to the element. If the voltage is missing you'll have to trace it back to the control board. Just be very careful around the 240 AC.
http://fast.wistia.net/embed/if...l=true&autoPlay=true
Dabenthall
#3 Posted : Tuesday, December 20, 2016 11:11:13 AM(UTC)
Dabenthall
Im replacing that part next. If that doesnt do it I've been told we are getting a repairman. Lol
