I recently had a flood from a lose drainage hose on my washer. This caused an issue where my dryer wouldn't start. Per some suggestions I read, I bypassed the thermal fuse to test it and the dryer started tumbling again. Only problem is that there is no heat now. I already ordered a new thermal fuse and it is yet to arrive. I'm wondering now if I don't have an additional problem. If I bypass the thermal fuse would I still get heat? Is there something else I should replace?
