My condenser fan will not turn on. I replaced it and still nothing. I have also replaced the inverter so I know that the fridge and freezer both operate now. I have a small fan aimed at the back of the fridge just to keep it cool for now.
Any suggestions?
Thanks!
Groups: Expert
Sometimes the control board processor is screwed up and it's just one pin and it only needs to be off by 1% (for this particular problem) and the fan will not work, ever. It's an issue that can't be conquered. But generally the board can be repaired, it's rare to run into that issue.
