AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer trips circuit breaker, upon resetting fault code PF flashes on control panel
Dryer quit, reset C/B restarts dryer and the C?b trips after about 4 rotations of drum. Switched out C/b's thinking they could be failing and get the same results. Have checked the Thermistor and OHMS at 10.32. Any suggestion?
Dryer Repair
