herman_the_german
#1 Posted : Friday, November 11, 2016 7:13:39 PM(UTC)
herman_the_german
The machine was not completing a full wash cycle. It started and then stopped midway.
I opened it up and saw a burnt thermal fuse. I replaced that.
Then the ON button was not responding.
If I attempt to reset it (hi-temp scrub/energy saver dry/hi-temp scrub/energy saver dry) I only get a partial reset.
I don't get the circling lights I used to. I get the lit 88, then I get a partial light: I only get two lines on, first two verticals then a horizontal and a vertical. It seemingly runs thru the rest cycle, but by the end everything turns off and the ON button is still not responding.
By now I've also replaced the control panel and still no luck.
