I have a EdgeStar CWR461DZ 46 Bottle Built-In Dual Zone Wine Cooler. in 2015 it started freezing up more than normal. I turned it off then manually defrosted it. Over the summer while I was away it stopped cooling however the fan was running. I turned it off for 48 hours and then plugged it back into a GFI outlet. It blew that GFI. I then plugged it back into the main outlet that is non GFI and it runs the fan but I am not hearing the compressor. This is a 2012 model. Is it worth trying to repair? Any ideas on trouble shooting>
