jporter88
#1 Posted : Monday, November 7, 2016 3:39:58 AM(UTC)
jporter88
I have a Whirlpool portable dishwasher WDP350PAAB4 where the heating element had cracked. I replaced the element and it is not heating the water. I have continuity through the element and about 18 Ohms resistance. If I test the voltage at the leads with the DW running and on heat mode, it's only reading about 2.0 Volts.
ThatGuy
#2 Posted : Monday, November 7, 2016 12:46:02 PM(UTC)
ThatGuy
Groups: Expert
United States
Check your wiring and thermal fuse. If they are OK, its probably the electronic control board.
Probably a fried relay or burnt trace.
W10804120
Whirlpool W10804120 Cntrl-Elec - AppliancePartsPros.com
jporter88
#3 Posted : Tuesday, November 8, 2016 5:43:05 AM(UTC)
jporter88
W10804120
Thank you for the reply. I traced the wires back, there are no fuses or anything inline. Wires go right back to control board on the door. No damage to wires. There is a thermostat under the tub. Any idea what that controls? and would that interfere with the element working?
ThatGuy
#4 Posted : Tuesday, November 8, 2016 12:40:52 PM(UTC)
ThatGuy
Groups: Expert
United States
They call it a thermostat, bu it can "open" keeping voltage from getting to the element.
Whirlpool WP661566 High Limit Thermostat - AppliancePartsPros.com
