Panel reads "Door Open" but the door is closed. We have checked for continuity, and replaced the main panel...still reading same. Error code is E91.
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Used meter to test continuity.
Groups: Expert
Well, if you are sure about the switch and the wiring, that pretty much just leaves the board.
