derekirving
#1 Posted : Sunday, October 30, 2016 8:17:28 PM(UTC)
derekirving
I have a Maytag Atlantis washing machine. All of a sudden it is tripping the house circuit. When I reset it instantly trips circuit again. If I unplug washer, reset circuit and re-plugin washer there is a spark and the circuit trips again. If I use a diff outlet in the house, the washer will run but there’s a buzz/lights will flash and evenly the washer will stop. I tested the lid assembly and it seems OK the only thing I can think is the motor or ?? It's impossible to keep the washer plugged in without it tripping the house circuit. The outlet seems OK as I can keep the dryer running (after resetting). This just started happening a few days ago, prior to that it's been fine.
Here's a picture of the motor (i unplugged washer connector). I'm not sure how to test this either. I do have a multimeter, but I don't know which connectors to test for ohm, etc
derekirving
#2 Posted : Sunday, October 30, 2016 8:19:59 PM(UTC)
derekirving
UserPostedImage
ThatGuy
#3 Posted : Sunday, October 30, 2016 9:37:38 PM(UTC)
ThatGuy
Groups: Expert
United States
Have you tried running it with motor unplugged?
Does it still trip the breaker?
derekirving
#4 Posted : Monday, October 31, 2016 5:44:14 AM(UTC)
derekirving
@thatguy - Great idea - YES without the motor plugged in line with washer, I can get water to run and the circuit doesn't trip. So that would lead me to an issue with the motor (replace the motor ?)
ThatGuy
#5 Posted : Monday, October 31, 2016 11:41:28 AM(UTC)
ThatGuy
Groups: Expert
United States
Take a good look at your motor, look for melted plastic, burn spots, or the smell of burnt electrical. You might even open up the cover on the motor start switch and see if its burnt up. Just a take pictures for reference before you start.
It could be the timer, but that doesn't happen very often.
derekirving
#6 Posted : Monday, October 31, 2016 11:47:06 AM(UTC)
derekirving
Thanks - I would have guessed that IF timer it would have shorted without motor plugged in when it was able to fill with water (?). The one thing of note is sometimes when washer was working, there would be water left in and I have to run spin cycle a second time. That being said I didn't notice any smell of burnt electrical or notice burn spots on motor.
