tater9.75
#1 Posted : Monday, October 24, 2016 12:40:59 PM(UTC)
tater9.75
I have a whirlpool dryer, model number is WGD5540SQ0. It will heat up when I start a cycle as I see the igniter glow and the flame turn on. The vent tube will heat up as the cycle continues but never gets real hot. I would say after 5 to 10 minutes the vent tube starts cooling off and is cold to the touch. I have tried doing a timed cycle which seems to dry the clothes a little better and a regular cycle and there is no difference in the outcome of the clothes. I have replaced the thermal fuse and cycle thermostat thinking it was one of those.I also cleaned the vent tube and the back of the dryer from lint. Any help to get it working properly would be great as buying a new dryer isn't an option.
ThatGuy
#2 Posted : Tuesday, October 25, 2016 12:44:10 PM(UTC)
ThatGuy
Groups: Expert
United States
Can you hear or see if the ignitor comes on after it first warms up? If it does but doesn't light, then it might be the gas valve coils failing.
Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.com
Gas Dryer doesn't stay hot (Dryer Repair)
by jenny58 2/16/2009 5:19:24 PM(UTC)
