We've got a GE range with a double-oven and the lower oven is misbehaving. If I set the temperature to anything it only gets to about 127F no hotter. The lights aren't working in that oven (the work on the upper one) and it doesn't appear as though the convection fan is coming on either. The upper oven and the burners work as expected and the control panel works fine too. Is there a breaker for the lower oven or something similar?
Thanks, ennoble
